Kampus Merdeka
Kampus Merdeka
Fluent – Fluid Properties
    • Muhammad Ar-Razi Alifiansyah
      Hi, so i was changing my fluid properties at fluent and i searched for the density of this fluid (i'd tried a fluid that's not on fluent database) on google. Is it okay to use the density other than that on fluent database? or is there will be a difference in the results
      thank you in advance
    • Raihan Lutfianto
      Hi Ar-Razi. Yeah, that is totally fine! You can define a material with data from other resources.
  • The topic ‘Fluent – Fluid Properties’ is closed to new replies.
