August 11, 2023 at 5:24 amDana KangSubscriber
Hi, I'm having trouble opening the Fluent software. It worked perfectly until yesterday, but it fails to validate its connection when I click 'Start'.
I noticed it changed the working directory from C:Users to the one in the image below.
I already tried reducing the number of cores but the issue persists and Fluent doesn't start itself at all - it worked perfectly with 10 cores yesterday.
Would appreciate help regarding this problem, thanks!
August 11, 2023 at 2:57 pmGeorge KarnosAnsys Employee
Please try changing the working directory to a writeable directory with no special characters.
- The topic ‘‘FLUENT application failed to validate the connection’ error’ is closed to new replies.
Ansys Innovation Space
- RSS is disabled.
- ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va)
- ansys fluent error when opening it “unexpected license problem”
- Elastic Licensing DNS gateway changes
- Ansys 2024 R1 – The installation completed with warnings/errors.
- Poor quality mesh at trailing edge for 3d wing
- Not find helic___[]_.tgz file
- LS-Dyna Beam elements outputs
- Fluent
- Workbench license error
192
178
162
141
