Topics relate to Fluent, CFX, Turbogrid and more
fensapice error
    • Neil McFadyen
      we are getting a
      the library not found error even after I created a link for it
      /usr/local/ansys_inc/v222/fensapice/bin/nti_sh: error while loading shared libraries: libqwt-0.4.1.so: cannot open shared object file: No such file or directory
      ls -l /usr/local/ansys_inc/v222/fensapice/lib64
      lrwxrwxrwx 1 root root      11 May 26 15:58 libqwt-0.4.1.so -> libqut.so.6
      lrwxrwxrwx 1 root root      11 May 26 15:29 libqwt.so.4 -> libqwt.so.6
      -rwxr-xr-x 1 root root 1688328 May 16  2022 libqwt.so.6
    • Neil McFadyen
       I fixed the typo for the link,
      lrwxrwxrwx  1 root root      11 Jun  6 10:17 libqwt-0.4.1.so -> libqwt.so.6
      but now getting another library error
      /usr/local/ansys_inc/v222/fensapice/bin/nti_sh: error while loading shared libraries: libQt5PrintSupport.so.5: cannot open shared object file: No such file or directory
    • ANSYS_MMadore
      Can you please check your installation to our listed prerequisites?
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/installation/unix_platform_libraries.html
    • Neil McFadyen
      I installed
       yum install qt5-qtbase-gui
       yum install qt5-qtsvg
      which don't seem to be in the library list but now the library errors are gone now getting a different error - not sure this is the correct way to run fenaspice in batch
      /usr/local/ansys_inc/v222/fensapice/bin/nti_sh /home/xxxxx/run_FENSAP_Shot1_FORCLUSTER/solvercmd 2>&1 > fensap.stdout
      nti_sh -
      Undefined variable (Path)(error: 1999)
      solver.cmd contents:
      #!/bin/sh
      #cwd
      rm -f .solvercmd.out
      export FLUENT_EXE="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/bin/fluent"
      export FLUENT_INTEL_MPI_VERSION="2018"
      export NTI_DATA="/usr/local/ansys_inc/v222/fensapice/data"
      export NTI_PATH="/usr/local/ansys_inc/v222/fensapice/bin"
      export Path="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin;\usr\loca
      l\ansys_inc\v222\fluent\fluent22.2.0\multiport\mpi_wrapper\lnamd64\intel\;\usr\local\ansys_inc\v222\
      fensapice\bin\;$Path"
      rm -f .mem_monitor
      rm -f converg
      rm -f gmres.out
      rm -f surface.dat
      rm -f hflux.dat
      rm -f out
      rm -f abortmesg
      rm -f probe.out
      rm -f fensapstop.txt
      rm -f soln
      echo STEP:FENSAP >> .solvercmd.out
      which "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra"
      if [ $? -ne 0 ]; then
        echo ERROR: "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec
      .hydra" not available >> .solvercmd.out
        sleep 1
        exit 1
      fi
      "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" -local
      only -np 1 "/usr/local/ansys_inc/v222/fensapice/bin_mpi/fensapMPI.exe" >> .solvercmd.out 2>&1
      "\usr\local\ansys_inc\v222\fensapice\bin\testWaitFileNormally" fensapstop.txt .solvercmd.out NORMALL
      Y,normally,request
      if [ $? != 0 ]; then
        echo ERROR: execution error >> .solvercmd.out
        sleep 1
        exit 1
      fi
    • Neil McFadyen
      i fix the PATH variable (caps needed) but still getting an error related to mpi options [mpiexec@c201m128.local] match_arg (../../utils/args/args.c:254): unrecognized argument localonly [mpiexec@c201m128.local] HYDU_parse_array (../../utils/args/args.c:269): argument matching returned error [mpiexec@c201m128.local] parse_args (../../ui/mpich/utils.c:4770): error parsing input array [mpiexec@c201m128.local] HYD_uii_mpx_get_parameters (../../ui/mpich/utils.c:5106): unable to parse u ser arguments ERROR: cannot stat fensapstop.txt ERROR: (abnormal program end of NFS/filesytem problem) ERROR: execution error
    • Neil McFadyen
      more .solvercmd.out
      STEP:FENSAP
      /usr/local/ansys_inc/v222/fensapice/bin/fensapMPI: error while loading shared libraries: libmpi_wrap
      per.so: cannot open shared object file: No such file or directory
      #!/bin/sh
      #cwd
      export PATH="/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin;\usr\local\ansys_inc\v222\fluent\fl
      uent22.2.0\multiport\mpi_wrapper\lnamd64\intel\;\usr\local\ansys_inc\v222\fensapice\bin\;$PATH"
      rm -f .mem_monitor
      rm -f converg
      rm -f gmres.out
      rm -f surface.dat
      rm -f hflux.dat
      rm -f out
      rm -f abortmesg
      rm -f probe.out
      rm -f soln
        echo ERROR: "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" not available >> .
      solvercmd.out
        sleep 1
        exit 1
      fi
      "/usr/local/ansys_inc/v222/fluent/fluent22.2.0/multiport/mpi/lnamd64/intel/bin/mpiexec.hydra" -np 1 "/usr/local/ansys_inc/v222
      /fensapice/bin/fensapMPI" >> .solvercmd.out 2>&1
      "/usr/local/ansys_inc/v222/fensapice/bin/testWaitFileNormally" fensapstop.txt .solvercmd.out NORMALLY,normally,request
        sleep 1
        exit 1
      fi
Viewing 5 reply threads
  • The topic ‘fensapice error’ is closed to new replies.
