August 31, 2023 at 12:59 amPak Him ChowSubscriber
I was playing with the plasmon mode excitation example from the Lumerical FDTD simulation software, I have successfully simulated the original example, but when I changed the 2 spheres into 2 triangles, I get no results. I have attached a screenshot of the azimuthal source electric field intensity of the 2 trangles with 4nm distance apart.
August 31, 2023 at 6:44 pmGuilin SunAnsys Employee
From the description it is difficult to provide any help. We do not expect that changing one object you will get expected result. It needs design, eg optimize the location, geometry, dimension and perhapes material etc.
From your result I can see very strong local enhencement. So I do not understand what do you mean "no results".
September 1, 2023 at 12:30 pmPak Him ChowSubscriber
Sorry for being unclear, what I have done was replacing the original spheres with trangles, placing them together with the tips of both trangles distancing 5-10 nm. I was expecting that strong local enhencement would take place around the both tips that are close to each other, but as you can see from the electric field intensity plot, it only happens around the other tips.
I have tried changing the dimensions of the trangles, distance between the tips, material of the trangles, switching to radial source, nothing changes. What can I do in order to see strong local enhencement around the tips where they are close to each other? The reason I want to achieve this is because ultimately I want to place a sphere in between the trangle tips to act as a quantum dot and see the local enhencement occuring around the quantum dot.
August 31, 2023 at 7:19 pmPak Him ChowSubscriber
September 1, 2023 at 6:32 pmGuilin SunAnsys Employee
Sorry, my yesterday's reply is not submitted successfully.
From your results, it is clear that the enhavement is inside the nano particle instead of at the gap of the tips. This means the excitation is not correct, or the device configuration is not correct. You can use log scale to check the field intensity at the gap. Such device needs careful design. unfortuately it is not that obvious whe things are changed. Please take some time to optimize the device configuration.
I guess it is due to the whipser gallery modes inside each triangle. Due to symmetry effect, the location of such modes cannot be uniquely positioned, probably due to excitation. Such personal observation is purely for your reference.
- The topic ‘FDTD Plasmon Mode changing shapes or adding structures does not work’ is closed to new replies.
- Ansys Insight:使用Checkpoint继续仿真被迫中断或已经仿真结束的文件
- 怎么修改生成远场图片的横纵坐标以及坐标标签的字体大小
- INTERCONNECT – No results unless rerun simulation until it gives any
- EME得到的S参数与监视器结果不一致的问题
- 如何直观计算3db带宽
- INTERCONNECT – obtain power output over time & check for SNR
- varFDTD半导体激光器建模方向及反射率设置问题
- Inverse Design Freezing Issue
- Calculation of correlation values in laser modulation bandwidth simulation
421
192
178
161
140
