Ansys Products
Ansys Products
“Failover feature ‘ANSYS electronics_desktop’ is not available” error message
    • runlolarun
      I've gone through the whole forum trying to figure out this error message, and, unfortunately, cannot.
      I'm getting the following error message when trying to start ansysedt.
      Failover feature 'ANSYS electronics_desktop' is not available.
      Request name electronics_desktop does not exist in the licensing pool.
      No such feature exists.
      Feature
      electronics_desktop
      License path
      [email protected]
      FlexNet Licensing error
      -5,147
    • George Karnos
      What is the full content of your license file. It could be that you have the new PPE Licenses.
      You can add the following switch to the command line to start using the PPE licenses:
      -UseElectronicsPPE
    • runlolarun
      Thank you for responding.
      Should I copy/paste my ansyslmd.lic file here? Sorry, just want to make sure it's secure.
      Also, license manager is up and running:
      Licensing Interconnect: running
      Licensing Interconnect Monitor: running
      FLexNet Licensing: running
      Both license server and clients are running on Linux.
      Just in case, here is diagnostics:
      $begin 'General Info'
      ProductName='ANSYS´┐¢ Electromagnetics Suite '
      BuildInfo='Release 2021 R1(Build: 2020-11-16 21:28:10)'
      ExeInfo='Executing from /path/Ansys-2021R1/AnsysEM/AnsysEM21.1/Linux64/ansysedt.exe'
      $end 'General Info'
      $begin 'Installed Components'
      $end 'Installed Components'
      $begin 'License Info'
      FlexlmVersion='2020.1029'
      AdminDir='/path/Ansys-2021R1/AnsysEM/shared_files/licensing'
      CustomerNumber='1140124'
      LicenseFiles('/path/Ansys-2021R1/AnsysEM/shared_files/licensing/ansyslmd.ini')
      ActiveServers ActiveHostIds Provider='ANSYS Common Licensing'
      'ANSYSLI Version'='2.2.1'
      $end 'License Info'
    • runlolarun
      Also, -UseElectronicsPPE option didn't make a difference. Sorry I forgot to include that information.
    • George Karnos
      You can post just the increment names.
      What is returned when you run:
      AnsysEM21.1/Linux64/mechanical/shared_files/licensing/linux64/lmutil lmstat -a -c 1055@licenceserver.edu
      Also, any errors in the license.log on the license server?
      Default path would be: /ansys_inc/shared_files/licensing/license.log
      Just an FYI:
      VENDOR ansyslmd 1056 should be VENDOR ansyslmd PORT=1056 if you want to use static port 1056.
    • runlolarun
      Hello. thank you again for all your help! License file is attached.
      lmutil result is also attached as pdf. Sorry, I kept getting an error message that my response had too many characters. If PDF is not good, please let me know.
      In license.log I am seeing bunch of "No such feature exists" error messages:
      11:43:57 (ansyslmd) UNSUPPORTED: "electronics_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:43:57 (ansyslmd) UNSUPPORTED: "hfss_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:43:57 (ansyslmd) UNSUPPORTED: "designer_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:43:57 (ansyslmd) UNSUPPORTED: "q3d_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:43:57 (ansyslmd) UNSUPPORTED: "maxwell_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:43:57 (ansyslmd) UNSUPPORTED: "simplorer_desktop" (PORT_AT_HOST_PLUS) user@server.edu[57322] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "electronics_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "hfss_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "designer_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "q3d_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "maxwell_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      11:59:42 (ansyslmd) UNSUPPORTED: "simplorer_desktop" (PORT_AT_HOST_PLUS) user@server.edu[69682] (No such feature exists. (-5,346))
      License file file is attached.
    • George Karnos
      We are not permitted to open any files.
      Look at the top of your license file. There will be a list of products.
      can you paste that list here. by the log errors, It does not seem that you have any Electronic Suite licenses
    • runlolarun
      Oh sorry about it.
      # 1. ANSYS Academic Research Mechanical and CFD (5 tasks): 2 task(s) Lease expiring 29-Apr-2022 Customer # ID
      # 2. Totem-MMX: 5 task(s) Lease expiring 29-Apr-2022 Customer # ID
      # 3. ANSYS Motion: 5 task(s) Lease expiring 29-Apr-2022 Customer # ID
      Is this what you were looking for? Thank you!
    • runlolarun
      I just got a confirmation that we are missing a license and should get an update soon.
      Thank you again for all your help!
    • stalin_97
      Security error throughout when opening electronic desktop suite 2022R, what is action to correct the erro
Viewing 9 reply threads
  • The topic ‘“Failover feature ‘ANSYS electronics_desktop’ is not available” error message’ is closed to new replies.
