Ansys Free Student Software
Topics cover installation and configuration of our free student products
ErrorThe license server may be experiencing a high demand or a temporary outage.
    • Yusuf Karabulut
      I was using the 23R2 Student version without problems before a week. But now I am having this problem. ı have checked the other titles but couldn't find a solution. I have tried to uninstall and install again but it didn't worked. I need an urgent help please.The error
    • Rajeshwari Jadhav
      Hi Yusuf,
      Go to C:\Program Files\ANSYS Inc\Shared Files\Licensing directory, copy the ansyslmd.ini file to the desktop location.
      Open the ansyslmd.ini file using Notepad and add the following lines –
      ANSYSLI_FNP_IP_ENV=1
      ANSYSLI_TIMEOUT_FLEXLM=20
      ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
      ANSYSCL_TIMEOUT_CONNECT=60
      ANSYSCL_TIMEOUT_RESPONSE=300
      Once you add the lines, click Save As > ensure that the save as file type is ‘all files’.
      Once the file is saved, please replace the old ansyslmd.ini file using the newly created one.
      Also set the following Environment Variable –
      Go to START > ‘Edit the System Environment Variables’ > click Environment Variables.
      Under the System Variables, please click NEW and create a new variable.
      Variable Name – FLEXLM_TIMEOUT
      Variable Value – 50000000
      Save it.
      • Config File Reset -
      Now open a file explorer and type %appdata% in the address bar.
      Locate the Ansys folder and rename it to Ansys.old.
      Now try launching Workbench application to see if it loads without any issue.
  • The topic ‘ErrorThe license server may be experiencing a high demand or a temporary outage.’ is closed to new replies.
