August 3, 2020 at 3:01 am
Keyur Kanade
Ansys EmployeeError: The mesh translation to fluent failed due to non-conformal, duplicate, or degenerate mesh elements.  -
August 3, 2020 at 4:15 am
prajput
Please make sure that you do not have any overlapping bodies in mesh. If the mesh is overlapping in any region, it will give this error. Please make sure you have used sharetopology options correctly in the geometry cell to avoid any overlapping regions in mesh. ``
August 3, 2020 at 10:00 am
Keyur Kanade
Ansys EmployeeI want to have a non conformal mesh. So I can not use share topology. Still it gives same issue. Why? -
August 3, 2020 at 10:20 am
prajput
If your geometry has high curvature faces at non conformal interface, please make sure that you have sufficient refinement on those faces. Please use refined mesh at the interface. This way cells will not have overlap and you could export the mesh.Â
August 3, 2020 at 10:32 am
Keyur Kanade
Ansys EmployeeThank you! It worked. I refined the mesh at the interfaces and could export the mesh. Thanks again! -
December 30, 2022 at 7:38 pm
Viewing 5 reply threads
- The topic ‘Error: The mesh translation to fluent failed due to non-conformal, duplicate, or degenerate mesh’ is closed to new replies.
Ansys Innovation Space
1414
1241
1118
1015
