October 5, 2019 at 2:07 am
Sayyed
SubscriberHello i need some help i am runing a an electric motor model made in maxwell and i am cosimulating it with simplorer .the error comes like ([Sim2000] Error - FEA1: ERROR - could not find a transient operating point before launching Maxwell >> Calculate at t=0.0005 s
(9:47:54 AM Oct 05, 2019)
please help me in this waiting for your kind response
February 12, 2020 at 6:20 pm
chandus127
SubscriberCan you please let me know if you've resolved this issue?
Thanks
Chandu
March 2, 2020 at 4:30 am
GayaniDeS
SubscriberHi,
Were you able to solve this error?
Thank you.
Kind Regards
Gayani -
September 24, 2020 at 2:05 pm
Sheetal_V_Umredkar
Subscriber.I need a help. i tried to simulate three phase IM in maxwell and all results are fine but after connecting that model with simplorer i faced issues like [Sim2000]
Warning - FEA1: apparently hit a motion limit at S=0 (0 deg) in the FEA solver
>> Calculate
(3:59:04 PM Sep 24, 2020)
What are the reasons for this type of warning and is it effect results?
Analysis set up for maxwell and simplorer. If tell me all below setting are correct or not? If not that are the setting?
July 4, 2021 at 6:38 pm
tca
Subscriber.Does anyone try to solve this warning?
- The topic ‘error in maxwell and simplorer co-simulation’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1363
1194
