Electronics
Electronics
Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Equivalent Circuit Model. Solution is not available.
    • Marcin Fisior
      When I want to add ECM in simplorer from Maxwell EddyCurrent solution, program says that there is no solution. However solution exist in the results tab in eddycurrent design. How to solve that problem??
    • HDLI
      Hello Marcin,
             I suggest to use "Add dynamic eddy current" in Twin builder-> add component-> Maxwell component when using eddy current solver. You need to define "frequency sweep" in Setup of the eddy current model and Parameter -> Matrix.
      HDLI
  • The topic ‘Equivalent Circuit Model. Solution is not available.’ is closed to new replies.
