February 23, 2020 at 4:02 pm
b0274
SubscriberHi!
I´m modeling a masonry wall with Solid65.
 Mi first model I used I used Drucker-Prager with
TB,DP,1,,, Â
Now in ansys help i found this
TB,CONCR,1,,,DP
and
TB,CONCR,1,,,DILAÂ
Some boy knows what is the difference between use TB,DP and TB,CONCR,,,,DP?
 When I use TB,CONCRE,,,,DP the model elements has become highly distorted.
 I appreciate any help Â
February 23, 2020 at 4:58 pm
peteroznewman
SubscriberThe concrete material is defined using a modified Drucker-Prager material model (TB,CONCR,,,,DP) or a Menetrey-Willam material model (TB,CONCR,,,,MW).
Exponential softening (TB,CONCR,,,,HSD2) is used with either concrete material model.
When using the composite Drucker-Prager with Drucker-Prager tension surface, dilatancy parameters are optional. The composite Drucker-Prager with Rankine surface requires a compression dilatancy parameter.
If you define dilatancy parameters, the following considerations apply:
You must also define the hardening, softening, and (where applicable) dilatation (HSD) behavior.
You cannot define failure joints, as they are valid only in the perfectly plastic base Drucker-Prager concrete model with associated flow (TB,CONCR,,,,DP).
To define dilatancy parameters, define the material data table (TB,CONCR,,,,DILA) and input the following constants (TBDATA):
- The topic ‘Druker-Prager Model’ is closed to new replies.
6495
