3D Design
3D Design
Dowel Pin Symbol ???
    • Dave Groff
      Is there a way ?
    • Subashni Ravichandran
      Hello Dave Groff
      Can you please elaborate on what you are looking for?
      If you are looking for Annotations and symbols, you can find some of the standard ones in the 'Details' Tab under 'Annotation'. (see below image)
      If you would like to Create new symbols, you can do from the 'Create' option in 'Symbols' under 'Details' tab. The created symbols will appear in Inset> Local
      You can also 'Import' a new symbol library, from Insert>Add symbol library (image below)
    • Dave Groff
      I am referring to the pic below - literally a "standard" dowel pin symbol.
      Is there a place to obtain a symbol library ?
      Hello Dave Groff
      There are no libraries for symbols that we offer apart from the ones already on SpaceClaim. This symbol can be created separately and imported into SpaceClaim.
    • Dave Groff
      Id imagine you by now get how this is a bit of a issue ? A dowel pin is a fairly standard thing and I would consider it a bare minimum item.
Viewing 4 reply threads
  • The topic ‘Dowel Pin Symbol ???’ is closed to new replies.
