Photonics
Photonics
Topics related to Lumerical and more
Defining GSST Material
    • Sudipta Biswas
      Any idea how to define Ge-Sb-Se-Te (GSST) in Lumerical FDTD. I can't seem to get the data for GSST anywhere or how to define it in Lumerical. Thank you
    • Guilin Sun
      You will need to find material data amd import  https://optics.ansys.com/hc/en-us/articles/360034915093-Creating-new-sampled-data-materials-in-FDTD
      if is dispersive.
      If it works at a single wavelength, the simpler way is to use nk material:
      https://optics.ansys.com/hc/en-us/articles/360034394654-Tips-for-using-the-n-k-material-model-in-FDTD
      and if it is dispersionless and lossless, you can simply assign one single real refractive index at the "index" tab in the geometry.
      However, you will need to have your owen data, either from lab measurement or search the literature.
    • Sudipta Biswas
      Thank you for your reply! I do know how to define it in Lumerical but couldn't find any way to get data for GSST. Most of the literature on GSST were based on experiments which makes it more complicated.
    • Guilin Sun
      Understand. You can google some papers by searching "refractive idex   Ge-Sb-Se-Te " and see if there is ready-to-use data.
  • The topic ‘Defining GSST Material’ is closed to new replies.
