Topics relate to Fluent, CFX, Turbogrid and more
Cut Model For Half for post processing
    • Agung Limowa
      Hi, I have a tunnel model with different gradients and different shape models, I want to make a contour to cut exactly the half (plan view) to look at the flow phenomenon. I have tried to create plan and it doesn't cover all the tunnel, i have tried several planes but it doesn't show in the same condition (some are high some are low due to different location, can i make cross-section across all the tunnel to divide it into half
      If the tunnels are all the same height have a look at "Transform" to create the surface: transform the top or bottom face.  Or have a look at the Imprint option.
      I teach a Uni course once a year. When doing that, one of the reasons I always recommend sketching the model out on paper before starting & writing on all boundary conditions etc is that you also figure out any post processing you know you need later. It's easier to build interior surfaces into the CAD model for later use in the solver.
    • Agung Limowa
      unfortunately the model is not on the same height and thats whats makes it difficult, it included several variety bending
      So, channel heights are all different? Do you have a separate label for the floor for each section? Otherwise, look at Imprint.
    • Agung Limowa
      unfortunately no, i just have the label for a wall (included the floor and the roof)
Viewing 4 reply threads
  • The topic ‘Cut Model For Half for post processing’ is closed to new replies.
