Topics relate to Fluent, CFX, Turbogrid and more
Converting .cse file into a .jou file for batch post-processing
    • JacobP
      Hi there,nI have created a .cse file from a previous CFD-post processing I conducted. I was wondering whether it's possible to convert this into a .jou file to submit to a HPC for future batch jobs?nThanks so much for your help!nn
    • DrAmine
      You can launch CFD-Post in batch and use that session file to teach Post to use a cst file and do whatever you want to.nncfdpost -batch .cse .resn
    • JacobP
      You can launch CFD-Post in batch and use that session file to teach Post to use a cst file and do whatever you want to.cfdpost -batch .cse .res/forum/discussion/comment/97412#Comment_97412
      Thanks so much for your reply. nI am a little unclear on the process still - this is quite new to me. nMy current procedure on solving a .cas on the remote High Performance Computers in the first place is to write a .jou file and upload a related .sh file to the same location, then run the command below.nqsub Filename.shnWould your suggested method work to post-process the previously submitted case (that has solved)?n
    • DrAmine
      Either you do the post-processing inside Fluent and there you need to start with at least -gu .driver null or to post-processing separately on the cluster using CFD-Post or EnSight. I am not sure if your cluster management allows you to do interactive things. For that reason you always can use batch post-processing with CFD-Post.n
    • JacobP
      Either you do the post-processing inside Fluent and there you need to start with at least -gu .driver null or to post-processing separately on the cluster using CFD-Post or EnSight. I am not sure if your cluster management allows you to do interactive things. For that reason you always can use batch post-processing with CFD-Post./forum/discussion/comment/97447#Comment_97447
      My cluster does allow me to connect with an interactive GUI. But, I am most interested in batch post-processing via CFD-post. My aim is to produce a .wmv file from the velocity contours of my solve at each time step, with the time value labelled.nIs there any documentation or tutorials you'd recommend to read up on this?nThanks so much for your help @DrAmine, !n
    • DrAmine
      Please read the CFD-Post documentation. If you are just interested in having animation, better to tell Fluent to export high quality pictures and create animations after the run finished using ffmpeg or Ansys EnVe.n
Viewing 5 reply threads
  • The topic ‘Converting .cse file into a .jou file for batch post-processing’ is closed to new replies.
