Topics relate to Fluent, CFX, Turbogrid and more
Compiling UDF on Linux HPC
    • 1829116
      I am trying to run a UDF for a dynamci mehs model on a HPC. I used these two lines to complie and load the udf:
      define/user-defined/compiled-functions compile "libudf" yes "udf.c" ""
      define/user-defined/compiled-functions load "udf.c"
      But I keep getting this error:
      Auto-compilation skipped. Could not find "libudf" or input files for creating "libudf" library
      Any thoughts?
    • Federico Alzamora Previtali
      is the udf.c file located in the working directory?
    • 1829116
      Yes my .sh code copies the udf.c to the directory. It created a libudf file with the udf.c in it.
      I created a libudf file in the directory manually before submitting the job bu then the temperature I patch to a part disappears. What is the TUI to patch this:
      Thanks
      Hadi
    • 1829116
      I am using this command:
      followup:
      /solve/patch () (part-steel_tube) temperature 30
      but getting this error:
      Error: eval: unbound variable
      Error Object: part-steel_tube
       temperature 30
      Try running the command locally one step at a time. I think you need to move the brackets.
      /solve/patch () (part-steel_tube) () temperature 30
    • 1829116
      I tried locally on step at a time and this worked:
      /solve/patch () temperature 30
      Nevertheless, when I monitor the temperature of the part-steel_tube, it is giving a wierd value:
      Any thoughts?
      Thanks,
      Hadi
      The output is going to be in Kelvin - all the Fluent UDFs use and monitors tend to return SI units.
Viewing 6 reply threads
  • The topic ‘Compiling UDF on Linux HPC’ is closed to new replies.
