June 18, 2022 at 10:10 pm
Md_Salem
Subscriber -
June 18, 2022 at 10:21 pm
peteroznewman
SubscriberWhat do you mean by "stability"?
If you were to apply an in-plane load on a section of one of the free edges, there is a critical load when the flat plate will buckle out of plane. Is that what you mean by "stability"? If so, you need to apply that load in a Static Structural analysis and then link the Solution cell of that to the Setup cell of an Eigenvalue Buckling analysis to find out the Critical Load Factor.
- The topic ‘check for structural stability’ is closed to new replies.
