Topics relate to Mechanical Enterprise, Motion, Additive Print and more
Bridge building in SpaceClaim with Modal and Harmonic Response Analysis
      Bbp_participant
      I created the video below to expand my skills in SpaceClaim.
      https://youtu.be/1UugzngfMb0
    • Raef.Kobeissi
      Very helpful video thanks Peter!
      Bbp_participant
      Here is the first video on Modal Analysis
      https://youtu.be/GyvvylC_nY8
      Bbp_participant
      This video shows the effect on modal frequency and mode shape of changing the concrete from one slab bonded to the weldment to a distributed mass that represents the same mass of concrete but in small pieces that don't add any stiffness to the structure.
      https://youtu.be/buEaYFVzKLU
      Bbp_participant
      While Modal Analysis shows deformation magnitudes that are arbitrary, this video shows how Harmonic Response can predict the actual deformation for a given amplitude of a harmonic load.
      https://youtu.be/X-P-f-YtbEQ
      • mine_mew
        Hi peteroznewman,
        I want to ask you about applying harmonic load on the model. When we apply force/pressure on the object, how can we know the amplitude of this sinusoidal load? Because we can put only the amount of force/pressure. For the frequency of harmonic load, is it vary between minimum to maximum value that we set on "Analysis setting"?
      Bbp_participant
      Bridge parameter study of Maximum Amplitude vs. Damping Ratio
      https://youtu.be/PACA-2-IyEc
    • Raef.Kobeissi
      I've always wanted to get involved with modal analysis! Thanks for sharing Peter!
    • AlexAlwithyou
      Just watched your very helpful video on this example, sovled my confusion about different types of entites.
      Thanks alot!
Viewing 7 reply threads
  • The topic ‘Bridge building in SpaceClaim with Modal and Harmonic Response Analysis’ is closed to new replies.
