November 11, 2025 at 8:43 pm
simonjoseph.koontz
SubscriberI am having a problem setting up a fluent simulation It involves an oscillating rigid body within a device cavity. It requires transient pressure based analysis using a dynamic mesh, created from a custom UDF. I can provide the inlet and outlet pressure conditions, but I believe all other variables should be determined through the simulation. Finally this is a 3D simulation, as the flow is highly turbulent and even a quasi-2D simulation is inefficient.Â
November 12, 2025 at 9:04 am
B D
Ansys EmployeeHello,
The details provided is insufficient to help.
Can you please provide following info:
- What are you trying to simulate?
- What is the expected outcome of the simulation?
- What specific problem are you facing?
Please share your specific query with good explanation so we, community can provide meaningful input.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
1494
1386
1209
