Topics relate to Fluent, CFX, Turbogrid and more
Boolean Subtraction
    • Pulkit Soni
      I made a car body using fusion 360, now i m getting tolerance mismatch and self intersection errors in CFD (Fluent) and I am unable to perform boolean subtraction operation on it, can someone please help me fix these errors
    • Osama Maddani
      I usually use Spaceclaim since its more convinient but your model looks like its not a solid, it should be a closed solid body, just make some wheel wells and make a flat floor to close the model, and that wing needs thickness it cant be just one surface, make sure that all of the surfaces are connected and make a complet solid body
  • The topic ‘Boolean Subtraction’ is closed to new replies.
