Topics relate to Mechanical Enterprise, Motion, Additive Print and more
An unknown error occurred during solution.Check the Solver Output on the Solutio
    • Aiswarya K P
      Can anyone please help me to sort out this error?
    • Nanda Veralla
      Hello Aishwarya,
      Have you checked the solve.out file for more information. Can you share the screenshot of that error message. You can look at the solve.out file, refer to this image below:
      Also, there's a warning message that tells offset type is not supported, although it's assuming to middle, it is recommended to chamge it manually and solve again.
      Nanda.
      If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
      • Aiswarya K P
        First of all, thank you for the reply.
        This is the error in solve.out file
    • Nanda Veralla
      Hello Aishwarya,
      I'm not familiar with this error, but after some review, this looks like a memory related issue. Although your model looks small, could you try switching to iterative solver and let us know if that didn't help. what product are you using? Student, academic or commercial?
      14.7. Equation Solvers (ansys.com)
      Best,
      Nanda
  • The topic ‘An unknown error occurred during solution.Check the Solver Output on the Solutio’ is closed to new replies.
