Topics relate to Fluent, CFX, Turbogrid and more
Actually i want to study effects of the flow on the balde in cfx. My blade is wi
    • Jack Cool
      • On what edges should i apply the inflation.(Which geometry to be selected in details of inflation and which boundary to be selected. )
    • NickFL
      If you are studying the fluid flow around the blade, you won’t need the blade itself. That is unless you have heat transfer or FSI or something else that you are requires you to model the blade. That means that you can suppress (or even delete) the blade (named ClosedSurface.3) in your model.
      The inflation will be on the fluid body (named Domain in your model). But it will only be on the faces that interact with the blade. When you are selecting the faces for the inflation’s definition, then you select all these surfaces–not the planar faces of the Domain body. (Side note here, you may want them on the shroud/hub surfaces too.)
  • The topic ‘Actually i want to study effects of the flow on the balde in cfx. My blade is wi’ is closed to new replies.
