Ansys Learning Forum Forums Discuss Simulation 3D Design The application failed to initialize, this may be caused by an issue with your install Re: The application failed to initialize, this may be caused by an issue with your install
Charudatta Bandgar
Hello Prathap Hoodi Muniraj
Yes, we can have a teams meeting. I can understand you have tried most of the things already.
Just to rule these possibilities out, can you once make sure that the files are extracted from the zip folder correctly and the installation is done by running 'run as administrator' (and you have the admin rights? Also make sure you have enough space in the drive where you are installing.
If you still face the issue, we can have a meeting to discuss. Before that can you send install.log file and install.err (if it exists) located at ~/Ansys Inc folder? I will share these with the installation team, before having a meeting with you so that it will be easier to resolve the issue.
Can you also share the system specifications?
Regards.
