Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Import parameters from workbench to fluent › Reply To: Import parameters from workbench to fluent
November 24, 2017 at 5:43 pm
dmendez.3
Thank you Â
With your help and the ansys help I could do it.
It is posible defining a scheme proc with lambda command using the same name of the variable that is in workbench.
I m doing a PhD about continum granular models and i'd need another thing...
I don´t know how to extract the value of the coefficient of restitution for use it like field function in "custom field functions". I'm not sure if this is posible...
Thanks a lot.
