Ansys Learning Forum Forums Discuss Simulation Fluids Importing the working torque into UDF Reply To: Importing the working torque into UDF
sdarmayuda
Hallo everyone,
I have found how to retrieve the torque from Fluent. However, there is still error in the code after I intepreted the UDF code. it says "line 14: parse error". I think it is about the macro DEFINE_TRANSIENT_PROFILE. Can somebody help to show me the mistakes about this macro? Thank you very much.
Here is my UDF Code:
#include "udf.h"
DEFINE_ON_DEMAND(wall_forces)
Domain * domain = Get_Domain (1); /* For multiphase flow, you need to set the Sub domain */
Thread *t;
real CG[3], force[3], moment[3];
t = Lookup_Thread (domain, 13); /* 13 is the ID of the wall to be determined. */
NV_S (CG, =, 0.0); /* coordinates of the center position to find the moment. */
Compute_Force_And_Moment (domain, t, CG, force, moment, TRUE);
Message("f=(%e, %e, %e), m=(%e, %e, %e)n", force[0], force[1], force[2], moment[0], moment[1], moment[2]);
/* force [0], force [1], force [2] are respectively x, y, z-direction forces, Is the sum of the force by the force and the shear stress due to pressure. */
DEFINE_TRANSIENT_PROFILE(testudf, CURRENT_TIME)
real omega_ts=0.0; /*starting omega*/
real omega_tf=600.0; /*final omega*/
real Jt=0.000554; /*Moment Inertia of the Turbin*/
real delta_t=0.0001; /*delta t simulation*/
real CURRENT_TIMESTEP;
real CURRENT_TIME;
real alpha_t; /*angular acceleration*/
Thread *t;
cell_t c;
t=Lookup_Thread(domain,9); /*Cell Zone ID = 9*/
begin_c_loop (c,t)
alpha_t= 15*moment[0]/Jt; /*there are 15 blades, x axis as rotation axis*/
omega_ts+=alpha_t*CURRENT_TIMESTEP;
if (omega_ts > omega_tf)
{omega_ts = omega_tf;}
THREAD_VAR(t).fluid.omega=omega_ts;
end_c_loop (c,t)
