Ansys Learning Forum Forums Installation and Licensing Ansys Products Problem with workbench 18.1 Reply To: Problem with workbench 18.1
peteroznewman
Uninstall ansys, and clean out two folders. In Windows Explorer, type %AppData% in the path field. You will be in the Roaming directory. Delete the Ansys folder, then go up a level and down to the Local directory and delete that Ansys folder too. Reboot the computer.
Unless you need to use 18.1 for collaboration with other students, download ANSYS Student 18.2, unzip to a folder on your computer, then right click on setup.exe and Run as administrator.
