Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to simulate 3D analysis of water flow(open-channel flow) for an undershot turbine. › Reply To: How to simulate 3D analysis of water flow(open-channel flow) for an undershot turbine.
October 28, 2017 at 3:07 pm
Raef.Kobeissi
Hello VINOD
It appears to me that you have multiple objects that are sharing interfaces between each other (contact region). You have to make sure that contact regions between fluid objects or fluid-solid objects should be assigned as ‘Interfaces’ and you need to couple them in the Interface Window.
Cheers
Cheers
