Ansys Learning Forum Forums Discuss Simulation General Mechanical Heat flux through given paths do not match the heat flux reaction probe Reply To: Heat flux through given paths do not match the heat flux reaction probe
Arun
The total heat flux probe gives the heat flux at a given surface irrespective of direction and this may be the reason why the results differ. To check the result in a better way evaluate the heat flux results in specific direction (X, Y or Z) at a given surface
