Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler › Reply To: Imprint baffles on volume bodies in ANSYS Spaceclaim Direct Modeler
October 17, 2017 at 7:48 am
To work with baffles in ANSYS Spaceclaim Direct Modeler, Volume bodies and Surface Bodies have to be generated/moved in 2 different components at the upper level. To imprint the baffles on the volume bodies, the Share topology option has to be set to Merge between the 2 main components. Example: Design (-> Share Topology : Merge) - Component1 (-> Share Topology : Share) -> Volume Bodies - Component2 (-> Share Topology : None ) -> Surface Bodies
