marissa.gaylord
Hey Guys Sorry for the delayed response on this. Below is an image of how I solved this issue. I right clicked on the Ansys workbench, then under compatibility tab. I selected "Override high DPI scaling behavior. Scaling performed by Application." Then select apply and reopen Ansys. You may need to restart computer to have your select applied but I did not have to restart.  I hope this helps others that are having similar issues.
