Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet › Reply To: Creating an internal inlet within a geometry or using outlet velocity turbulence profile for inlet
August 30, 2017 at 11:13 am
Holger Grotjans
Hi, did you consider to create a local source in the domain? So instead of an inlet you can create the AV at the required location by a source term.
