Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Explicit Dynamics body didn’t move › Reply To: Explicit Dynamics body didn’t move
January 10, 2025 at 2:27 pm
Hi
Place the wall a bit closer (gap should be much less than 27778 mm/s*0.001 s ~ 27 mm , so say 5 mm or so).
Then:
Can you show the frame displacement at the simulation end time (0.001 s) , because your sim. goes only up to ~1E-8 so perhaps it has not run fully (due to error, etc.) – we want to see if it has actually travelled the gap between the frame and wall.
Also show the stress contour of the wall to see if it deflects.
All the best
Erik
