Ansys Learning Forum Forums Discuss Simulation General Mechanical Modeling Weld for 3D simulation. Reply To: Modeling Weld for 3D simulation.
Kaushal Vadnere
You can use weld connections for 3D bodies as well using the Weld control (No need to have batch connections), but you will need to add 'Automatic (PrimeMesh)' method to solid bodies which is the same error that you can see in the messages. You can select different options under 'Create Using' in Weld details to suit you model based on details in the help document shared before.
