Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › JavaScript Runtime Error in AQWA Pre on Windows 11 (Version 24H2) › Reply To: JavaScript Runtime Error in AQWA Pre on Windows 11 (Version 24H2)
January 10, 2025 at 8:36 am
Mike Pettit
Thanks for that. In this case I can give you specific instructions to fix the issue:
- Close Ansys Workbench and all Workbench editors
- In Windows Explorer, navigate to C:\Program Files\ANSYS Inc\v242\aisol\DesignSpace\DSPages\scripts
- Make a back-up copy of DSTreeScript.js
- Open DSTreeScript.js with a text editor
- Search for the text 'TreeHandler.RemoveAndFillChildNodes'
- You should have 2 matches, at line numbers 210 and 218. Add a new line before each match, and add the text 'if (parentNode != null)'. The modified lines should look like this:
- Save the file, then re-open Ansys Workbench and try to re-open the Mesh editor.
I hope this helps.
Mike
