Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Spray modeling › Reply To: Spray modeling
January 9, 2025 at 5:40 pm
sjohn
When I switch to a different user defined material, it has properties that are temperature dependent and that causes the energy to turn on by default. I am starting with water (Fluent material) to make sure the model is working well and then will switch to my user defined material.
The droplets should have an average diameter of 16-18 micron (theoretically) and the target cell size is 80 micron in the zone where the droplets are formed. Below this zone, where the fluid escapes the cell size is 600 micron
