Ansys Learning Forum Forums Discuss Simulation General Mechanical Laser surface texturing Reply To: Laser surface texturing
Rahul Kumbhar
Hi Ad,
If I am assuming correctly, you want to analyse the specimen which has grooves /geometrical depressions due to laser process. If correct, you can just cretae a geometry with such grooves/depressions and simulate it in Mechanical. You can use Spaceclaim/Discovery to create such geometry. Following post has one example of embossing. Similar method can be followed to create grooves
https://innovationspace.ansys.com/knowledge/forums/topic/projecting-text-onto-a-curved-surface-and-embossing-and-engraving-in-spaceclaim/
