Ansys Learning Forum Forums Discuss Simulation LS Dyna Compression of a rubber sample in LS Dyna ACT Workbench Reply To: Compression of a rubber sample in LS Dyna ACT Workbench
javat33489
Sir, this is what I noticed, when I converted the rubber into particles, the picture became like this, gaps appeared:
But if you select the particle body, then the selected body is as before without gaps:
