Ansys Learning Forum Forums Discuss Simulation Fluids Hydrogen-diesel Combustion mechanism Reply To: Hydrogen-diesel Combustion mechanism
jcooper
Hi Usman:
Among the Forte output files, there should be some text files that show the preprocessing diagnostics.
  If you go over these you will see the errors that were issued.
Sometimes these are just warnings.  If you were able to run the simulation, things are probably ok.  Most serious errors will prevent the simulation from proceeding.
