Ian Pond
This appears to be an Ansys licensing issue. It sounds like you have setup your Ansys License server and Ansys Licensing client, can you open the client licensing settings and verify that you have a green check mark when "testing" the connection. If it is green, you should be able to check the "Features in use" on the left side of the window and you should verify that your Thermal Desktop licenses show up there. Is your license file hosted locally on your machine, such that you computer is both the server and the client or are you connecting to a central server?
