Ansys Learning Forum Forums Discuss Simulation General Mechanical Joint force probe output data in global reference frame. Reply To: Joint force probe output data in global reference frame.
dlooman
If you only have 1 or 2 joints you could use the command fsum to get the joint forces in global coordinates.  The procedure would be to create a named selection for one of the faces the joint is scoped to and then issue the commands below:
cmsel,s,face_name
fsum
allsel
