Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Help generating flow path axial turbine blade with export points › Reply To: Help generating flow path axial turbine blade with export points
January 8, 2025 at 2:39 pm
Check if the blade height is higher than the shroud-hub height. Ensure the blade height is taller than the shroud sketch line when viewed perpendicular to the xz plane. Blade surfaces should intersect the hub and shroud lines.
