Ansys Learning Forum Forums Discuss Simulation Fluids Help generating flow path axial turbine blade with export pointsHelp generating Reply To: Help generating flow path axial turbine blade with export pointsHelp generating
Petros
The FlowPath does not need to intersect the blade. It can even be in a completely different circumferential location relative to the blade. The error might be due to hub/shroud sketches being too far from the blade, which along the Hub/Shroud Offset % can give this error. Try tweaking this value or bring the sketches closer. Also maybe increase the Point Tolerance.
