Ansys Learning Forum › Forums › Discuss Simulation › Fluids › HET_RXN_RATE UDF › Reply To: HET_RXN_RATE UDF
January 7, 2025 at 11:26 am
OK, UDFs aren't something I use much (I have people to do them for me!) and we don't support at the same level as the main code. pt[2] is the third phase, remember numbering starts from 0.Â
I think the UDF will overwrite the panel setting, but I'd set to none and check it's still working to be sure.Â
