Ansys Learning Forum Forums Discuss Simulation Fluids HET_RXN_RATE UDF Reply To: HET_RXN_RATE UDF
sjohn
Hi Rob,
I tried your suggestion but it looks like that is not an acceptable syntax. Here is the error I get after compiling (while my orginal code would compile fine).
Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.
Compiler and linker: Clang (builtin)
Compiler path: “C:\PROGRA~1\ANSYSI~1\v241\fluent”\ntbin\clang\bin\clang-cl
Linker path: “C:\PROGRA~1\ANSYSI~1\v241\fluent”\ntbin\clang\bin\lld-link
C sources: [‘simple_reaction_4.c’]
simple_reaction_4.c(18,30): error: subscripted value is not an array, pointer, or vector
real vof_l = C_VOF(c, tp)[0]; /* Fraction of liquid phase */
1 error generated.
scons: *** [simple_reaction_4.obj] Error 1
Instead of 0, I used 2 and got the same error. 2 is the ID of the primary phase in the Multiphase physics GUI.
