Ansys Learning Forum Forums Discuss Simulation Electronics Y wiring method and the start and end points of winding. Reply To: Y wiring method and the start and end points of winding.
Tamami Yamanaka
In Maxwell 2021R1 and later versions, File > Open Examples > Maxwell > Electric Machines > Interior Permanent Magnet.aedt is provided as an example of an electric machine with an external inverter circuit.
For earlier versions, you can use File > Open Examples > RMxprt Examples. Circuit Type: [Y3] in the machine properties of the RMxprt project tree indicates a Y-connected three phase drive circuit. (e.g. bldc > ws-1.aedt)
After analyzing these RMxprt models, you can create a Maxwell 2D/3D motor model including the external circuit from RMxprt > Analysis Setup > Create Maxwell Design.
Ansys Maxwell 2024 R2 Help > RMxprt Help > RMxprt Machine Types > General Data for Brushless PMDC Motors
Ansys Maxwell 2024 R2 - General Data for Brushless PMDC Motors
Ansys Maxwell 2024 R2 Help > RMxprt Help > Postprocessing and Generating Reports in RMxprt > Creating a Maxwell Design from RMxprt
Ansys Maxwell 2024 R2 - Creating a Maxwell Design from RMxprt
