Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › The meshing algorithm cannot find matching topology › Reply To: The meshing algorithm cannot find matching topology
December 26, 2024 at 3:59 pm
peteroznewman
In Mechanical, on the Display tab, click the Show Vertices button, and Close Vertices button.
If you see non-matching vertices on the High and Low sides, open the geometry in SpaceClaim. On the Repair tab, click Extra edges and remove any with the green check mark, then click Split Edges and remove any with the green check mark.
