Ansys Learning Forum › Forums › Discuss Simulation › Fluids › udf compiles the air equation of state › Reply To: udf compiles the air equation of state
December 23, 2024 at 1:21 pm
Fluent has some internal logic for density that means you can't code up pressure dependent density unless it's real gas: you use the built in models otherwise. Not sure how you'd have "negative pressure" as we usually solve against gauge.Â
