Ansys Learning Forum Forums Discuss Simulation Photonics Mode Source and Metal BC Reply To: Mode Source and Metal BC
Dev
The mode source has a limited size, which is why it utilizes PML or, in some cases, PEC. Sources require appropriate boundary conditions to adhere to physical principles. For instance, a plane wave is infinite in extent, so periodic boundary conditions (BC) or symmetry-type BCs, such as PEC/PMC in specific cases, are applied on both sides.
It’s important to note that for mode sources (and Gaussian sources), their geometric size can be as large as the simulation domain. This is because the mode properties define and control the physical size of the source.
This articles give more insight:
Mode source - Mode analysis - Simulation Object – Ansys Optics
Starting with metal BCs in FDE simulations – Ansys Optics
Thanks
