Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How can I do plate heat exchanger analysis? Please help › Reply To: How can I do plate heat exchanger analysis? Please help
December 20, 2024 at 11:07 am
In CFD we'd tend to set the inlet value and calculate the outlet condition. So, in your case you can't force a fixed dT but instead need to understand why it might differ from the experiment. In your case I suspect there is no connection between the hot & cold zones so revisiting the geometry to apply "share topology" might be a good place to start.Â
