Ansys Learning Forum Forums Discuss Simulation Photonics Absorption cross-section of AuNR excited by prism-based TIR Reply To: Absorption cross-section of AuNR excited by prism-based TIR
katsuya2
Hi, I simplified the geometry as follows:
I want to realize the total internal reflection at the interface between ITO and water.
As a result, I got the following absorption cross-section.
I performed 4 AuNRs by rotating 30 degrees and observed a constant 445 nm peak and 660 nm cutoff.
However, I still see the peak at around 530 nm (I believe this is a transverse mode of localized surface plasmon resonance), and it changed as a function of the polarization angle.
Do you know why I saw the constant absorption cross-section cutoff?
I'd appreciate your response.
Best,
Katsu
