Ansys Learning Forum Forums Discuss Simulation General Mechanical Rivet and double riveted joint Reply To: Rivet and double riveted joint
deepak.deepak
Frictional contact is a nonlinear contact type and is slightly more computationally expensive than linear contacts like bonded or no separation. However, using a linear contact in place of a frictional one in such scenarios would be an oversimplification and could adversely impact the accuracy of the results.
